Ice Cream Jonsey
Thanks to Google Groups being worthless, I haven't been able to find any info on either issue. But here's what I've got:
I have a 25" WG25k7184 monitor running jrok's Williams board. The monitor is displaying a picture that is just a tiny bit too wide. Of the 8 pots the thing has, none effect horizontal size. It seems like there is a width coil that affects that. However, I've tried to manipulate it and it's had no effect. I guess there is a plastic tool or something that people use to change adjust those things? I'm amazed that using a torq screwdriver of approximate size won't affect the coil even though it's clearly turning.
Secondly, every few minutes the entire display will wig out. It's frustrating because I don't even know what to call this, much less search on it. I would describe it as the vertical hold going bad for a split-second. It seems to happen after the monitor's been running for 10+ minutes. Is there a name for this? Has anyone else experienced something like this?
Thanks in advance.
Thanks in advance.
