jimbodeanny
- Joined
- Oct 24, 2004
- Messages
- 4,533
- Reaction score
- 881
I pulled the two Sanyo 20EVZ monitors that are in the Super Punch-Out I'm restoring, as both of them have similar issues. I went through and recapped both of them (with full capkits from Peter @arcadepartsandrepair), since new caps usually fix geometry issues in my experience. After recapping both chassis, I fired them up and verified the B+ was 108v. While the picture looked much better (as expected), the geometry issues were still there. So I replaced the filter caps and B+ POTs on both. I fired them up and dialed the B+ to 108v. Still no change. I found ONE thread that dealt with a pin cushion issue, in which the fix was replacing IC601. I swapped one of the IC601s with one I bought from Peter. Again, no change. I've messed with all of the POTs both on the remote board and chassis itself (h.hold included), but can't adjust it out. At this point, I'm considering sending both chassis in for repair.
I searched through thread after thread, but haven't been able to find anything quite like my issue, other than that one thread I mentioned. It's strange to me that both of these chassis have this issue.
Here are a couple photos of both monitors. It's difficult to take a photo that clearly illustrates the issue, so I drew some lines around the areas that are problematic. Hopefully it helps.
Here's the first (upper) monitor:
And the second (lower) monitor:
Has anyone else experienced this?
Again, here's a recap of what I've done.
- Recapped both monitors (w/capkits from Arcadepartsandrepair)
- Replaced filter caps (w/ones from Arcadepartsandrepair)
- Replaced B+ POTs (w/ones from Arcadepartsandrepair)
- Tried swapping IC601 (w/one from Arcadepartsandrepair)
I don't want to spend too much more time poking around with these monitors as this is holding up my restoration, but thought I'd ask before sending these off for repair.
-Jim
-Jim
