Talon2000
Atari Force Liberator
Can't seem to find it's listing on KLOV..
It works, but has a graphics glitch on the planet horizontal lines going through the planet. Hope it's not major. Quick self test shows Ram, and Roms good. and no errors..
And Bezerk
Won't know if it will run until I put a chassis in the monitor, but other than that it's all there. Interesting thing about the paint on this. Looks like they used sand in the paint or primer before paint. It's like an 80 grit texture all over the cab, even the monitor area. Plus they never smoothed out the ply wood, knot holes are prevalent. Maybe Stern should have stuck with Pins?
I like the fact that the cab has an access panel on the front. The board set slides out after you unlatch it. So you can do board work without having to pull it away from the wall.
And Bezerk
