TWILIGHT ZONE error codes on test...
BC3
Connecticut
I did a test and found the following:
1) ck sw 53 left ramp enter: - the entrance fence wire was out of its hole, still inop as I dont know if its bent or supposed to be under the switch,,have to find close up pic.
2) ck sw 74 gumball popper (?)
3) ck gumball diverter (?)
4) clock is broken (uhh yeah , its GONE)
5) Ball popper opto is stuck - I think this is the big culprit.
6) The "extra ball' button in the front of the machine: the light and switch are hanging out of the button itself inside the machine and I'm not sure what holds those components in to button for it to work..got to be a clip missing.
7) The reset button for high game says its wiping it clean but after the countdown to do so..it still reads high scores
Thanks for the help... bc3
______________________________________________________
ohhh and one more thing...
every once in a while I hear a large rapp from inside the machine..it sounds like a pinball is dropping off the playfield and onto the wooden decking of the machine. I havent found any balls inside, but two were in there earlier when I was cleaning it out. I figured they had either been put there, or down while in transit (unlikely) bc3
