Tutankham only runs at 4.2 volts???
TheOldMaster
Pennsylvania
I know, i tried the repair section, but any ideas here?
sometimes the last thing someone wants to do is look at more stuff to be repaired.
heres the scenario:
the game started having sprite problems, like incorrect color bitmapping on the explorer.
so i figured start by checking voltages. voltage was 4.2 ,
the game has a switcher power supply,so just to be safe i tried a new one and no luck.
i set the new switcher at 5 volts and just solid color screens game does not boot.
when i lower to 4.2 volts it works fine but with slight sprite problems in
the vertical center of the screen.
any help apreciated, thanks.
heres the scenario:
Did you pull, clean and reset removable chips??
