Tutankham Instruction Sheet
Phetishboy
Avon, Minnesota
So I decided to finally fix the access door on my Tutankham. Someone had tried to pry it open and busted the top of the MDF off all around the lock. Then they drove in 2 screws, (sort of into nowhere) trying to keep it shut. When I pulled it out and and removed the instruction sheet, this is what I found. Looks like it has been shat upon at least 3 or more times. In addition to the stains and yellowing, the text is also blurry like it's a 20th generation copy of a copy. So my question is, does this sheet exist in digital form anywhere? Or do I have to retype it?
How'd you fix this? I have a similar situation with one of my cabs. The part where the cam lock holds the cabs was ripped out.
It was just the front half that had been ripped out around the lock area probably about 5 inches wide by 2 1/2 inches down. I just put up two crude forms and used metal infused Bondo. Sanded everything flat, including forming the lip and gave everything a nice satin black paint job. Then I finally installed a lock and found a cam that worked perfectly.
P3 in the manual
Print on weathered paper if you want to keep the patina look: https://www.amazon.com/Stationary-C...ext&ref_=fplfs&smid=A2V2M9O3VOQ6U3&gQT=1&th=1
Man, there's a lot of cool exploded view diagrams and other pages in this manual that feel like they would be better suited for the inside of the front door then what's there. I feel like printing all these pages out and then choosing a couple. Maybe I'll plaster the entire inside of the cabinet with the manual pages.
