Turbo Tall CARS problem???
itobandito
Connecticut
I have heard of the trees and buildings being streched out before but it appears the cars on my machine are too tall, I actually never realised that they weren't supposed to look like this until I saw another machine at Funspot in NH. Anyone know how to fix this or have more info on it. I messed with the two pots on the board but it didn't seem to do really anything. Check out the picture below to see what I am talking about.
I had this problem once I ended up having to replace the 2 pots on the board and it fixed it they both have to be adjusted just right tho
Hmmm I think this may be what I have to do. I messed with the two pots on the board and they appeared to do absolutely nothing to the trees or the buildings which was kind of a red flag when I noticed it. Think I should probably do it regardless but anyone else familiar with this issue?
So I swapped the pots and no luck with the cars. I bought a replacement board set from someone on KLOV who showed me the boards working in a picture. The cars in the picture were the normal size. Put the replacement boards in my cabinet, and sure enough, still too tall. Anyone have any idea? The vertical height on the monitor looks fine. Prior to getting these replacement boards, I was able to swap pots from on of the other sets I had and for a little bit the car size was correct. The picture tweaked a little bit though, you could tell the cars wanted to get large again as the height of them is what was tweaking a bit. Any Ideas guys? At my wits end with this machine, really want to keep it but I dunno, may have to junk it if I can't get it working.
