Tunnel Hunt - I'm an idiot!
Is it not working?
According to the pinout, if you put it on upside down, pretty much all the voltages would be on the same pins, but the outputs for video and switches would go out on the wrong wires.
The only difference is that +sense and +5 would be swapped, and -sense and gnd would be swapped, but I think they are the same signal anyway.
Your +10.3reg would move one pin, but that one isn't connected on the harness, so may go nowhere on the board.
Perhaps you'd send the +5 for the switches along the video line (which is normall y about +2.5) so maybe you blew something in the color drive circuit of you monitor?
I'm getting video - very clear video of some random characters on the bottom 1/4 of the screen. Nothing else. Before that it looked like an error screen of some kind en espanol.
On the AR/II board had R30 toasted, so lacking that resistor I used the AR/II from my Centipede. And the board ground was toasty, so I repaired it. It was pretty late last night, and I plugged it in without thinking about it first.
Try a different board
Eh... it may have happened... it wouldn't have been advertised though ;)
But in any case the power is symmetric on most Ataris, so plugging the board in backwards shouldn't dreally hurt anything....
Well, that's good. I'll start troubleshooting soon.
This cab is a mess; mouse nests, broken plastics, broken wood, no back door...I'm in for a lot of work.
