joemagiera
Thread Manager
- Joined
- Mar 22, 2003
- Messages
- 6,162
- Reaction score
- 1,073
tube swap candidate? & other tube swap questions...
Will this work for anything (G07, 4900, other)?:
Magnavox TV:
Model: 19C522
Made: May 1986
RF4252 WA04
Tube:
Company: NAP
Model: MV A48AAN01X
on tube itself: 51 19V90
Neck has 9 pins present (not counting key pin)
plus a spacer (non-present) pin on each side of the key pin (so 2 spacers)
plus a 10th key pin
Also, for those that know if it will work, can you explain to us clueless people (i.e.: me), how you know it will work? Can you explain what any of the numbers above mean? About all I can figure is the 19V90 is a 19" tube with a 90 degree deflection (not even sure if that's right).
And if a tube is a candidate, is there anything else to save off the donar TV besides the tube itself? Do you ever need the yoke or rings or neck board or anything else?
Thanks much.
Magnavox TV:
Model: 19C522
Made: May 1986
RF4252 WA04
Tube:
Company: NAP
Model: MV A48AAN01X
plus a 10th key pin
Thanks much.
