trying to turn a 50' sega water ski monitor into a golden tee golf
bgk969803
pekin, Illinois
does any one know how to wire a jamma harness into a 50" monitor from a sega water ski machine when i hook it up all there is is a bunch of lines across the screen the
Guess he must have found his answer while typing this post at the same time
no i have no idea how to do this there are colored cables that hook into a board then u plug the wires that u would plug into a reg monitor into that board but nothing happens if u know how plz share and this is the first time im trying this so any help would be helpful
you have to check your board and see if it is set to med. res monitor.
There should be a dip switch. If you set it to standered res, it might work?
Eric
Cointech
Eric
Cointech
The WaveRunner monitor is med res. I think GT only supports standard res and high res. If that's the case the projection monitor will not work for you. You would have better luck using an LCD or HD monitor.
My Golden Tee 2005 is either cga or ega (std or med) res, but will not run vga (high) res. What version of GT are you using?
My guess is that he is either running the board in the wrong resolution, or has the sync not hooked up, or hooked up wrong.
ok i wired the plug up to the board the same colors as the jamma harrness if u give me your email i can email u some pics of what i did
ok pics are uploaded if u look ull see the color wires comen out of the jamma plug and i pluged them into that board that is hooked to the monitor
Try swapping your synch and ground wire. It looks like you have your ground hooked to synch and vice versa. If you can unhook the small connector and take a picture of the wires it would be easier to tell.
here are some pics
Thanks for posting that. Lets me know my projection monitor can do standard res. I thought it could only do med. Do you have a pedestal or something else that will house the controls?
