Troubleshooting Williams Getaway II
tophatne1
Schenectady, New York
Or should I say just starting to try and fix issues with my first pin by someone with no knowledge of pins whatsoever! Haha. Yeah that's me.
I got the pin in great shape for $300. Unfortunately there are a few issues. I opened the manual today and holy sh+t there's a lot to look at on these things!
My first issue.
Every time the ball is loaded for the plunger it loads 1 ball and then immediately 1 more. So it loads 2 in all. Any quick ideas?
Thank you a ton!
Check to see if all the trough switches are working where the balls sit before they go to the shooter lane. Also check the microswitch in the shooter lane to see if it's activating or not.
Just put a ball in there and go to the test menu to those switches and they will say open when nothing's in there and closed when the ball is activating the switch.
The numbers of the switches are in the manual.
Thanks!
I will do the test menu stuff when I figure out how to get the DMD working. Haha. I failed to mention that one. Whoop!
I can check on the number of balls though. I believe there are 5 in there currently. Might be to many.
Thanks for the ideas!
I'm pretty sure high speed 2 only needs 3. Probably or I'd your isS
ues.
Thanks for this. Lots of info there. I guess I really need to try and find someone with a Williams pin around here so I can test my DMD board.
Anyone in the Schenectady,NY area that can let me test my DMD in their pin?
No problem, I hope you get it going. Great game, super fast. As Steve Ritchie said to my buddy, "it's a man's game".. hah.. whatever that means :)
