dochowl
I've got an Astro Blaster which uses the 5 G-80 boards inside a cage. The board is not booting as far as I can tell. Challenge is you can't get into the cage to test much of anything. Lots of ICs were replaced due to corrosion and rust. At this point I think all is well with that.
The sounds, speech, and eprom boards are all known working.
Any ideas how to proceed? You can see the picture below. This comes up immediately with no changes.
