Troubleshooting a Cave SH3 PCb
Luddite
Santa Cruz, California
My Pink Sweets board seems to work intermittently. The board looks really clean except for this one point in the picture. Can anyone tell by the picture what is going on?
I believe there was one of those tiny caps there as I found a loose one in the box when I got it. But there is no white box around it as there is for all the other caps as in the top picture.
I tested the large piece of solder in the bottom picture and it goes to ground.
Any ideas of what to try or who can fix this?
Thanks a bunch!
Looking at the close view picture, don´t seems to be affected by the glue/resin or whatever it is, anyway you could try to clean it up with alcohol and a brush, a toothbrush actually would be better if it doesn´t go out easily. I think the problem should come from another cause. Perhaps would be faulty solder joints...
