trouble with voyager start button
Deadpool66
Minnesota
Im have trouble putting one of the large lit start buttons togethr, Had this problem since I got it it wont stay connected to the microswitch housing is there a trick to these things?
Must be a common problem with these type buttons. I took my left panel out to replace the light bulb and the last person to work on it had a tie wrap fed behind the big plastic nut that holds it to the panel and pulled tight around the switch to help hold it together. I cut it off and put it back without it and it seems a little loose but hasn't popped off yet. Guess it depends on how many times it's been taken apart and put back together.:D
The notches on this buttons are different than the one that works fine. I got two new buttons from shopboy roy but its still not going together. Guess a rubber band will have to do pretty lame if you ask me.
