Hey guys. I have a Top853 burner. I can't for the life of me get it to burn the free play roms for Commando. Can't burn the original rom info back onto them either. They erase and verify erased quite easily, but when I put the roms in the burner, select the correct chip (in this case cm04 is TMM27256D-20 and cm03 is M5L27128K), load the correct info to the buffer and hit "write."
It sits there for a second then give me a write error "Write...Error at 00000 (FF)." It's not writing a damn thing because the chip still checks good for erasure after the burn attempt. The only real success I have with this burner on a regular basis is when I burn the 8mb and 4mb Toshiba roms for boards like MK. I can burn those all day and night with no problems. When I try to burn anything besides those, it never seems to work.
I tried to burn my own Vs. SMB HSS roms and ran into this exact same issue. Had to order the kit instead.
Any ideas? Thanks.
- Mike.
Any ideas? Thanks.
- Mike.
