Tron won't save settings or scores ?
RPO_Z06
norman, Oklahoma
All the sudden my Tron decides it won't save anything, I've checked the battery and its reading 3.6v and the output on the board reads 2.9v, the gray wire that goes to the board set reads 2.9v, I honestly can't remember if it should all be 3.6 or if the PS cuts it down some prior to output.
Its annoying loosing all my scores and settings every time I power it off..
I'm running the stock MCRII PS now but I also had a switcher conversion in the cabinet, it had the same issue.
Is there something on the boards that could cause it ?
EDIT: I believe I found the problem, I pulled the boards and the found the connection on the rear for the main harness was very dirty, just looking at the connection while the boards were still in the cabinet it looked fine but outside in good light it was terrible, I cleaned it up with a brass brush and it seems okay at least for the moment.
