also, one other thing i'd do is check your video cable. looking at it, the grey and black wires are the two sync wires. violet/tan is the video ground, and then you have the strand, and red/green/blue wires. i would try taking the cable out of the machine, and using a multimeter, meter each end of each wire together to verify continuity, mainly on the ground and two sync wires. you should get a reading of 0, indicating no resistance. if you get a reading off the chart, there's a problem with that wire.
