Tron White Screen after ribbon cable replacement
scamp
New Jersey
I've jsut replaced the rotten ribbon cables in my machine and put it back together only to see a White screen...It doesn't play when adding credits or anything...
Could I have put the monitor cable in the wrong place? I've seen a mention of this in a thread from searching.
Does anyone have a picture of the cables hooked up to the boards so I can ensure I did them correctly? Rookie mistake, usually I take a ton of pics before removing things...
**ALSO I noticed one of the yellow ground straps going from the filter board to the coin door and then just kinds hanging with an eyelet that looks like it should be attached to something...any ideas? I hadn't touched that and the machine was playing prior to changing the ribbon cables...
Fixed!!
I rechecked the ribbon cables and one of then. on one side was not seated correctly and a pin was not in...Upon fixing the machine came back on...
