Just checking -- it doesn't need to be inverted like a Nintendo monitor or anything, does it? I am trying to put in a much newer CRT from a conversion cab I am parting out. Usually I can just tie together the vsync and hsync into a single sync and it works, but I did that this time and got nothing. Every other wire has a direct connection, unless I have overlooked something. ??? I can get the TRON board to play normally to the monitor currently mounted in there on a direct connect, and I can get the new CRT to run whatever JAMMA board I feed to it with no issues. Maybe I'm just overlooking something simple here.
