Hello folks. I am not too electrical savvy so bear with me please. I have a Tron machine that is not working. The machine turns on, marquee lights up, machine makes buzzing sound from speakers. There is nothing on the monitor and game does not play. I did a little looking on the internet and read about power supply problems with these machines. I unplugged and reconnected all connectors on all boards. There was some corrosion on one of the connectors on the power supply board south of the leaky battery. I cleaned it and no change. One of the adjustable pots under the battery is corroded as well and does not turn. I am assuming I have a power supply issue, but would like to make sure. How do I check for proper power supply output to verify a power supply problem? I was about to order the power supply upgrade from the arcadeshop but would like to make sure this is my problem first. Any suggestions? Thank you.
