kjeffery
I just got a Tron and Ive been playing the hell out of it but it seems that the tank level is the hardest and always beats my ass. I am pretty good at the other 3. Any help on the tank area?
I always run up and duck into the warp area, but only far enough that the tanks can't shoot you (at or below the white line in the center of the aisleway). You gotta watch it though, some boards, you need to shoot a tank coming from the right before going all the way up that horizontal row above the warp box. Others, you have to get in quickly, and shoot tanks coming at you from 3 ways. The only tank board I don't do it on is the one with the red recognizers (which appear on level 5, 7, and every 5th level after that). I work my way to the top right corner on that one, since they don't shoot at you, and won't ram you in the little dead end, you can take a break![]()
You will eventually find the tank game to be the easiest.
I probably die the most on the tanks, due to what tron guy said. I think the grid bugs are the easiest. I rarely die on that one. MCP cone isn't bad for the most part, as long as you remember which way the cone is spinning. If it's one that comes down real fast, it's hard to correct if you head the wrong direction first. I don't have much problems at all with the light cycles. For score reference, I've gotten to a million two different times, and was about 60-70 levels in, so I have a little experience with this game![]()
check out the other tron videos by this guy, voxvid. he shows patterns for the first 5 levels.
Aren't there only 5 variations to the tank level?
