Tron Spinner Opto Orientation question
Zman6
Donor 2014-2015
Is this opto placement correct? Replacing and Not sure which should be S side and which is E side.
I should have an extra opto pcb lying around. I will try to check tonight .
Much appreciated, no huge rush. I just want to make sure I get it on there the right the first time because the traces are in such bad shape I'm gonna have to jumper several of the legs of the opto out to other points.
That looks correct. Looking at the schematic +5 runs through R106 which goes to pins 1&2 of the opto, aka the LED side, or [E]mitter.
