Tron sound is going crazy. Space Tennis!
dethfactor
Donor 3 years: 2011, 2013, 2021
Portage, Indiana
Hooked up my Tron up after it's been repaired and after some finagling
it fired up to where I can play it. The current issue is the sound, which is
kind of nuts. You can hear the regular sounds faintly but there's stranger
sounds coming out full volume out of the speakers. Not sure if it's the volume pot doing this or something else. Any ideas?
Video of what its doing. Language is a little graphic (it was late and I was frustrated)
http://www.youtube.com/watch?v=66BfA1Lu4kI
Put it in test mode via the switch in the coin door hole and run the sound test.
Also turn down the brightness a little or your neck board color pots, the blue setting is too high!
Thanks,
I realized the brightness and blue were off. I just wanted it to get it playing properly before I adjusted the monitor. Thanks, I'll give that a whirl.
Also pull out the little AMP board over the game board and check it for cold solder joints or broken transistor legs..
