Tron Shroud - How to get it out!?!?
Riffbear
Donor 2012
Vic, Australia
Hi guys, I'm trying to get my Tron shroud out so I can clean under the glass covering the monitor as its dusty..
For the hell of me I cannot get the shroud out!
I've undone the top 4 L plate screws and the bottom 4 screws - I can ever so slightly wiggle it left to right but cannot pull it out.
Looks like I might have to undo the monitor just to get to the glass and clean it.
Has anyone else found their shroud hard to remove?
Cheers.
I remember having a hell of a time trying to remove the shroud a long time back. I don't recall what I did though to finally remove it.
You have to remove the control panel, then the flat piece of metal that goes over the upper plastic and covers the bottom edge of the shroud. It should come out then. If I recall correctly there are only those three bottom screws holding it in, MAYBE some up top? But I'd have to go look.
Yup and just some extra careful wiggling. I recall it being of a pain
