Tron Quick question
bradp56
Baldwin, Maryland
What size molex are on the main pcb that is used for sound is it .100 or .156. The connection stinks and I want to redo it I think its 9 pin.
I knew it... I'm trying to find a replacement myself!
I'm heading down to my local electronics supplier, they have connectors like that; if I find a suitable replacement I will be sure to post!
As far as I recall, the PCB stack has a 0.156 right angle for the main power and 0.100 for everything else. If in doubt use a caliper (like this or this) and measure the pins center-to-center. If you don't have one then use a normal measuring tape with 1 inch intervals and count if 10 fit within an inch. :)
