jonathan1138
Tron Questions: Shroud bracked and Joystick set screw?
Hi - have two questions for Tron owners who can help, hopefully from their memory. I am assembling my cab now and want to make sure everything goes back as it was.
1. There is this bracket - called "Inner Shroud cover Mounting bracket". It is not flat - its curved a little, has a lip to it, has three screw holes, and (i think) it fits by the players / CPO blacklight.
Can someone explain how this mounts? I understand it goes by the Control panel / wood / works with the Lip of that wood - but it doesnt seem like a natural fit. Also, does it screw in with the bottom of the Inner Shroud blacklight cover?
2. When assembling the joystick, i used the manuals diagram. No mention is made of the Joysticks shaft and how it attaches to the assembly - it fits there, but is not screwed in (Joystick shaft fits onto a round "nub" just fine - i just dont have the screw for it). Does that need a set screw? If so, anyone know the size (figured i would ask).
Thanks.
Thanks.
