Tron questions - garbage on screen
scottmaggie
Donor 4 years: 2011-2013, 2024
Philadelphia, Pennsylvania
So started troubleshooting the Tron I picked up this week. I have 2 board sets to work from. One totally dead and one with garbage on the screen. I figure the one at least showing an image is the right one to start on so:
What should I expect to see on the screen with only the Super CPU connected? (power and monitor)
I have actually tried this and there is no change - same garbage on the screen which is why I think it's got issues.
If the vid gen and sound boards do in fact need to be attached too then my theory is out the window... :0)
Oh and the PS is reading correct voltages.
Any thoughts?
Your theory is out the window! :)
You need to hook up the video gen board before diagnosing.
Leave the SSIO out until you have a working CPU & video set.
same difference...
Ok got it. Good I can al least leave the sound board off. However with 2 different vid gen boards there is no change in the junk on the screen. Sigh.
Can you take a picture of what the screen shows? It could be the ROMs, RAM or something else and a picture will provide a place to start.
good news sort of
Went to StudioPaul's today to test my boards in his tron. After fiddling with my two sets I got one workingset though some sounds are missing.
My power supply is in fact faulty. Guessing the reset circuit... Better a bad power supply then bad boards right? :)
progress!
Ok for a temp fix I cut the purple wire. Voila the game came to life. Monitor needs a cap kit and adjusting but game is playing. Yea Tron!!!!
As for the sound issue channel 1 is garbled and 6 is missing. I assume they have to do with the few missing sounds.... any help here is appreciated.
