Tron Project FS on Long Island/NY
bob5150
Massapequa Park, New York
A project cab, to be sure, but a pretty solid one. Bought it about a year ago hoping to restore but it doesn't look like its going to happen. It had been converted to a 1942(I'm not sure if the 1942 board is present). Shroud and all fixtures are there and are pretty clean considering the conversion. I haven't had time to open it up and look around so I'm not sure about the power supply or any internal components.
In anticipation of the restore, a spinner and joystick assembly were purchased and will come with the cab along with a replacement wiring harness. Since the original cp was hacked up to accommodate the conversion, an original was purchased and will also come with the machine (you can take the hacked one too if you like).
Looks like there may be some sideart under the black paint used on the sides of the cab and most of the artwork on the inner sides of the cab is present. Monitor is there but I have not tested it(has what looks like 1942 burn) All and all, a nice candidate for restoration.
$250 cash in hand....come and get it. A solid candidate for a restore.
Located in Nassau County, Long island, NY.
BTW...I also picked up one of the grey Encom TRON repro marquees a while back(since the cab didn't have one). It also came with the coin door sticker. If you want that too you can have for the original 35 bucks I paid for it.
Cheers
Bob
