Tron PCB on a test bench
andy251203
Atlanta, Georgia
I'm trying to test out a Tron board that I have. What is required to get it to boot up on a test bench? Can I just put 5V, 12V, and ground on the appropriate pins and plug in a monitor and expect the game to fully boot (if it works)? Do I need to worry about putting anything on the reset and battery pins? Do I need to have any controls hooked up to get the game to boot?
Again, just looking to see if it works or not. Don't care about sound or controls.
You want +5 on the battery pin.
Some boards will boot with ~reset hanging, and some won't... in either case, you should be able to manually reset the board if you just leave it hanging.
