tron monitor- slightly blurry
kjoel
bayshore, New York
seems like the monitor is about 95% perfect except the text is slightly blurry. Tube has no burn on it. When I adjust the contrast on the flyback then the screen is sharper in the center and the text gets blurier or vicer versa. chassis was just recapped. The monitor is a 13" wells13k4606. I have 2 of these units and both do the saame exact thing in the tron. Gameplay and colors are ok good but not 100% sharp as they should be. Cleaning the glass monitor tube and glass bezel made no difference. Game board edge connector needs cleaning? Not sure- any ideas ??? :confused:
My buddies full size tron does the same exact thing too- HUH ??
OHHHHHHHHHHHH I am going to change all the pcb ribbon cables 1st then go from there. Anyone have his issue?
