I know someone (well, multiple people) will be able to help me out here.... So :
I just purchased two of the larger light cycles from the Toy line and already modded them to have wires for +5 in and the switch also has external wires now - and I disconnected the speaker. The sit great on top of the cabinet (custom header, in other words) - I will not drill holes into my new machine so the back portion at the top has enough room in the holes for wires - perfect to get my wires into the cabinet.
Well, now the question. I need an easy +5/Ground to connect to - I have the Flynn shot Tron LCD mod run to the extra connector in the header portion already. I would then like to link up the switch to both light cycle ramps so the lights only light up when you hit a ramp. Also, any idea what connectors I would need to make this a clean install? Can I just split the connection in the header where the Flynn LCD connects to? (I havent metered it to know if its 5 or 12 yet)
Any ideas?
Thanks!
Scott
Any ideas?
Thanks!
Scott
