tron linear power board no +5 (wacko actually)
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
I use my wacko to test monitor chassis' (g07)
Anyway, I was transferring a chassis back and forth as I generally do when doing repairs.
Anyway game was working perfectly, the next second I only have a blue screen.
I am literally running out the door so I just quickly tested the +5 on the first capacitor. It is something piddly like .8VDC
The next Cap has +12.32VDC
The power board has been rebuilt (a couple of years ago).
Probably one of the bottlecap transistors went out on me huh?
I have to run, I'll work on it later.
pulled both bottlecap transistors and they test good. maybe I'll find time to pull the smaller 3 legged transistor tomorrow to test.
Something in the 5v line though. I have +12 on the middle cap and +15 (or so) on the 3rd.
Though the Base (leg) on one of them has lost it's solder pad, and I cannot tell where it is supposed to have continuity.
I pulled all 3 of the heatsink transistors, they tested good, thoigh the tp31 had a lower resding than a spare I had so I swapped it.
I get +5.33 when the 2-15 pin molex' are disconnected, it drops to .8vdc when they are connected. I'm sure I've had this problem before, I guess I'll go look for old threads.
I did run a couple of jumpers from the heatsink transistors where I thought the solder pads were questionable.
Problem solved , U2 was bad.
