TRON LE Pinball Video Everything But The Portal
That is the worst angle I've seen. Camera needs to be higher and closer.
I really wish someone would video tape with the glass off and just manually go through the modes from the 1st to last insert.
Not trying to rain on your parade, but hard to see anything in the vid. I think you can pick up tripods really cheap at walmart.
Watching the new vid now.
OK I watched most of this. I'll have to really diagnose it when I get home from work. Here are some issues I have with the software. For modes like LightCycle MB, it doesn't tell you want to do to complete the mode. Is all it is just hit the ramps for points? It seems a lot of modes are like this.
Another thing... with DaftPunk Multiball, uh... the pf lights are still on. I thought it was to go completely out and the only lights were to be the fiber optics???
PortalMB - There should be animations running on the DMD, not just text saying portal multiball.
On RGP some people said they had 1.0 code on their LE some said 1.1. What code was on the machine in the vid?
Thanks for the vid! I'm really impressed with the color changing and pulsing of the ramps. The color is synced to the mode...very cool. The deep purple of the Disc Multiball looks like a blacklight!!!
Daft Punk MB only plays a beatbox and then as soon as you hit the disc it goes right back to Derezzed. I don't hear "castor" during this mode.
It almost seems like Daft Punk mb is a re-hashed mode.
In Daft Punk mb you get an add-a-ball after hitting the recognizer disc. Isn't there another mode that does the same thing? Quora MB maybe? I remember playing the pro and there was a mb mode that hitting the recognizer disc for so many shots gave add-a-ball too.
If so it would explain the Derezzed music and they didn't change it.
Get Quora mb and then go into DaftPunk mb and see if there are any differences.
Nope, In Quorra MB going back to Flynn's Arcade just kicks it out so you can't enter EOL mode once QMB is activated. In End Of Line MB it beatboxes until you hit the disc and then goes into Derezzed. It tells you to hit spinning targets which just acts as a multiplier. It doesn't seem to do anything in Daft Punk mode except display the animation. It goes dark at first in EOL mode but then the lights come back on.
No I don't mean to stack them, just wanted to compare them individually.
I could have swore that when you started Daft Punk or End of Line MB, whatever it is called, it showed you can add-a-ball.
I thought in Quora MB you can add-a-ball as well.
I was these 2 modes are basically the same with maybe different animations and light shows.
Gotcha, the main difference is that in QMB you can still hit anything else and have it activate. Like Follow Gem, ZUSE, ETC. In QMB when you knock down the recognizer wall you get add a ball.
I have to agree, the fiber optic work on the ramps is far superior to using EL-wire which would have just been one color. It looks really good.
The music also sounds good, but it seems to be a bit too repetitive. At least there isn't as much annoying voice call-outs as there is in Avatar.
Sound and playfield lighting I think is nice. DMD animation is really below par and lame, especially the light cycle race animation. All-in-all I don't see this game as being a "dud" but I bet "pro" owners are going to be hella pissed.
