I have two different color sets of keys as well, but I've not tried to remove the translite. The game is in a position that would make it hard to try to do that now.
My translight was locked in. No problems removing it after unlocking it.
no problem, it's pretty easy. Here is the link to the download:
http://www.sternpinball.com/GAME-code.shtml#
1. you will see a click to download, click on premium/le code
2. drop the files after you downloaded them to a thumb drive usb stick
3. there will be a read me file for directions if you don't have the manual
let me know if you need any more help.
Dave
Found a cold solder joint on the ball trough jam opto. My wife was playing the flippers just went dead. My dealer actually knew exactly what it was as soon as I explained what happened. Found it and reflowed the solder.
Just installed my LED backbox kit and Flipper Fidelity Speakers too.
Vid of my Translight
http://www.youtube.com/watch?v=5NMcDXgcjac
Maybe this is just a general Stern pin issue, but it is happening on my TRON LE. Just about 50% of the time when I turn it on I only get general illumination -- the game does not start, no DMD, etc. If I turn it off and back on it will start fine. Happening enough just to piss me off. Anything to check for or is this going to be a call to Stern?
Believe it or not - this is "normal" (although 50 percent is very high). There is a thread over on RGP about it (something like Jon Favereaus Iron man is dead).
That happens once every 15 times on my Iron man. I didnt think anything of it for the last year and came across that RGP thread - turns out this is a very common problem with Sterns dating back to TSPP!
Report it to Stern, they know all about it. Surprised others dont have the issue.... also not sure why your frequency is higher than others. The average seems like 1 in 10 - 20 times.
This has happened to me about 4 times now, I have over 550 plays.
good grief...you too?
well, i guess i shouldn't freak out when it finally happens to me....certainly seems like it will.
The whole power driver board would need to be replaced or the CPU board. I heard from my distributer that is the cause. I even posted on the Stern forums.
http://sternpinball.com/Forum/messages.aspx?TopicID=247
