Tron LE 3 Bank issue
jackal2001
Pennsylvania
Anyone else have the issue where you start a game and hit the 3 bank target enough times to drop it. When it drops, it then goes back up, then drops again.
I've also seen some other weird stuff where the 3 bank will cycle multiple times and it even got the ball caught in the spinning disk.
I'll be calling Stern tomorrow, but wanted to see if others had issues with the same. I'm running 1.1 code.
i have def got the ball stuck behind the bank on the disk, but if u wait it cycles the bank down if there is no action after 30 seconds? the spining dissk rubber top ripped off twice while we were playing it !
Every Stern game I've played w/ the 3-bank sometimes has an up-down issue. It's just that the bank isn't quite hitting the switch quite right, so it goes up and down till it senses it. You can try adjusting the switch if it's doing the up'n down dance too much.
Greg
Guys please keep the comments to Tron issues. I have a SM with the same exact bank target with no issues.
I've found that the switches are so sensitive that when the motor goes to the next position, it backs off a hair which opens the switch, as the motor continues then to the next position, it closes and then opens the switch again until it reaches the next position.
I've already had the ball stuck back there while the disc was spinning at full speed trapping it back there causing it to go crazy.
When you first hit the bank to drop, mine almost always cycles 2 times even though I have tried adjusting the switches to make it work correctly. I want to know if it is a coding problem or switch problem.
I replied on RGP also, but on my tron le, the targets goes up and down and then stay down.
Not sure I understand your statement. The 3bank starts out in the up position. What happens after it goes down the first time? Does it stay down or come back up again?
Thanks vector. I think it is an issue when you get a ball trapped in there or slam the ball into the bank when it is going up and down.
