Tron Inner Bezel Artwork Glue
butthead
bath, Pennsylvania
What works best to get this chit off? I got the decals off without breaking the damm shroud , That is some tough stuff they used for glue.
Thanks for any input.
Tom
take a heavy paper towel and soak it in goof off, then drape the papertowel over the glue area and press it down like a skin graft :) let it sit and it will loosen the glue.
That is what I did 24 hrs. Later It came off . That is some tough chit.
Thanks, Bill
I just got to enjoy the experience of this adhesive. Nice loud noise there when you remove those decals (about 20 min each)! I got one side cleaned last night and then let the other half "soak" overnight. I got the Goo Gone spray gel...hoping it would stick better. Still took forever. Fortunately, my rear piece around the plexi is okay, so I'm just going to let it be. I know Goo Gone is supposedly okay for clear plexi, but I still masked it off just in case. Now I've just got to wait for my Phoenix art set to get here!
Krudd Remover
I have had better experience with KRUDD REMOVER than with goo off or goo be gone
I used KRUDD REMOVER on a Tron shroud about two months ago and it worked like a charm..
Just a suggestion for anyone else...I did have to do the paper towel trick..saturating it and letting it sit for 24 hours...but all the gunk came of easier the goof off ever did..
True
That tron bezel was such a pain. I stripped it a little at a time so I wouldn't get too frustrated. When putting on the inside bezel stickers it is really easy to miss a tiny air bubble or too. But they will show up big time when you're playing the game with all the lights reflecting on it. Its definitely helps to have a friend help you.
