TRON G07-CBO P901 Connector
zz0ljf
Chesterfield, Michigan
I'm putting my Tron back together after a lengthy restore and need some help. On the P901 power connector of the G07-CBO monitor chassis what lead does the black 115V wire coming off the isolation transformer go to? The male / female quick disconnect connector lets you plug it in either way, which I thought was odd. Both leads on the chassis board are labeled "L." The one on the right is fused to fuse # F902. Typically you fuse the hot wire. Am I correct to assume that the black 115V wire from the isolation transformer goes to this lead and the neutral goes to the non-fused lead? I should have marked it with a sharpie before unplugging it, but typically power connectors are keyed to prevent this. The first & second pics are of the P901 connector off the G07 chassis. The third and fourth pics are of the connector running from the isolation transformer.
Since it is AC .... and it is coming from an isolation transformer....it doesn't matter.
Hence why both inputs are labeled "L" for Line, it doesn't care which.
I'd change one of those ends though so you had the match so they'll actually lock together.
