jp.jones
Tron Full Wiring Rig, Tron Upper CP light fixture, shroud (Now Taking Offers)
I have some rarely seen parts for sale (unless my search-fu is extremely weak)... you are welcome to make me an offer.
Tron Shroud - See pics on 2nd page of posts. The art and shroud are in the condition you'd expect. There is a crack in the plexi at the back of the shroud and is barely noticeable from the front. There are no cracks elsewhere (that is a jar in the background). Make offer plus shipping (I'll have to have a box made and packed by the mailboxes people - it will not be cheap to ship).
Tron Upper Control Panel Florescent Light Fixture - Tested working, $75 shipped (the long connector is still available)
Tron Full Wiring Rig. This is it. For those of you that have come across a sad, gutted cab in the hopes of one day restoring it will want to especially consider this.
I got this many years ago from a run.. long story short.. I pulled the entire wiring from the machine. The switches, interlocks etc are all still attached to the wiring rig which is attached to the power assembly, attached to a plank of wood. There is only one cut wire, and it appears that it is factory-intentional. I have cleaned and painted appropriate parts, sanded the wood and added new screws etc. The sad cut power plug was de-soldered and a new 3 prong 8ft power cord was added in it's place. See post #17 for updated pics. You'll want to re-pin all connectors, clean and test everything before hooking up to a monitor or PCB. As a side note, the PCB I also pulled was fully working, so it was not blown out by any power supply problems.
I purchased a power cord, hooked it up and powered on. Metered the service outlet, monitor plug (iso transformer works), 3 (or 4) light fixture connectors, all read 115+ vac. Quiet hum from transformer. Square 9 pin had 18vac on orange wire. At some point I'll connect it to a MCR power board and see what's up, but for now this is how far I got.
Pictures will be posted tomorrow evening.
$500 plus actual shipping.
SOLD - Short connector Lamp
SOLD - MCR Monitor brackets.
SOLD - Set of 9 cabinet brackets (MCP translite bracket not pictured) I could identify marquee brackets, upper shroud bracket, upper plexi retaining bracket, monitor rails?. Not sure what the rest are for. 125 shipped (only sold as a set). (This set does not have a lower shroud (flat) bracket).
