Tron Full cabinet problems
DACRepair
Michigan
well i found this old tron machine and i had it working, until i tried putting it into test mode, now all i get is a white screen, ive let the backup battery off and made sure the ram was reset etc, but still no luck, anyone ever have a similar problem?
update: i checked the ram/rom test and it seems to not be functioning, coin counter does not work
I will tell you the same thing everyone else on here will. Check all the voltages at the harness of the Power supply board first.
Next would be replace the interconnect ribbons.
Then disconnect the SSIO board and test to see if that's what's causing the lockups. IIRC, you can remove the SSIO board, and the game will (if it still does) work but will pop up a SSIO error.
