Dantebean
At the touch I am getting shocked at the coin door lock, metal coin drops, and the power button. How do you resolve issues like this? This is a first for me. Whenever I touch any of those spots it resets the game.
Your field ground is missing. Is the third prong on your plug cut off?
There should be a ground that runs to the control panel too - look for a flat strip of metal about 1cm wide covered in yellow insulation. All metal parts that you could touch on the outside should all tie back to the 3rd (ground) prong on the power cord.
It was a bad slam switch. It had paper between the contacts that I took out to test it last night. It does still have ground noise associated with lights, he put in a new coin light when it was on and you could hear the interference get worse. Any help with that would be appreciated.
Um, You? What do I win for having the right answer!!
