Tron - Disc of Tron Sound Boards
hsapinball
Rogers, Arkansas
Does the original Tron share the same sound board with DOT?
I have a DOT with a bad sound board and I was going to find a replacement board so I am trying to see what my options are.
I know that EDOT uses a different sound board with panning. My DOT is just the regular UR with the non-panning sound board.
The DOT and Tron SSIO boards are different. The first one is DOT and the second is Tron. Tron is missing the chip at A3, not sure if there are any other differences. (Both are missing A 7407N in the center as I had to rob them)
The part numbers are the same, differing only in revision. I would image you could swap them, but I'm not going to recommend it because I've never done it and I don't know for sure.
