Tron blacklights?
FlashbaxArcade
Burleson, Texas
isn't there suppose to be a blacklight installed right below monitor bezel with that 1st plexi with decor on it? also, is there suppose to be a blacklight on bottom plexi too or just regular bulb?
thanks
The very bottom has a "white" blacklight - F15T8-BL.
The one just above the control panel has a "blue" blacklight - F15T8-BLB.
The marquee and behind the MCP cone artwork is just a regular cool white - F15T8.
All us the FS-2 starter.
Bulbs can be bought online, or at some local shops...
cool, thanks! that's all i need to know right there! BUT, never have seen or even heard of different colored(white and blue) blacklights.
I have a place called the "Lightbulb Shop" here in town that sells both the white and blue blacklights right off the shelf.
otherwise, Bulbman on the internet carries them...
the Tron i just aquired is totally missing this light right above CP! is this an original light and bulbs on original Tron?
The four bulbs required in the original Tron are as I mentioned above. If you look in the actual manual, you'll see them listed there also, but probably as T12's instead of T8's, but I don't think you can even get T12's anymore...
great info.....thanks!
