Tron Black lights Question
dj dns
Donor 2015
Dallas, Georgia
Which are the correct black lights for the Tron and where do I get them from. I heard one is a white black light or something like that.
The bottom has a "white" blacklight - F15T8-BL the rest are standard black lights F15T8-BLB, the upper MCP is a standard white bulb.
Try bulbs.com that's where I found the oddball one for mine.
The one in front of the spinner and stick, and below the monitor, is the "black" black light. The one at your waist calls for a "white" black light. It can be ordered online, however alot of people, myself included, just put a "black" black light at the lower location. The white one emits more UV, and is bad for you. That light is also at the height of my 4 year old right now, and I don't want that causing her any problems.
VG
You need:
1 - F15T8-BL for below the control panel
1 - F15T8-BLB for above the control panel
1 - F15T8-CW for behind the MCP cone artwork above the monitor
1 - F15T8-CW for the marquee
All use FS-2 starters...
Call around to your local non-chain lighting stores. You won't have to pay for shipping, will support local business, will have it quicker, and won't have to worry about it breaking while shipping.
Yep, got mine from a local light store too.
Bought mine at bulbster.com... good prices and selection, and with spares for my other games in the order, shipping costs werent a problem.
By the way, on my TRON, I ended up swapping out the white blacklight in the lower spot for a regular blacklight bulb, as the florescence of the worn ink (and highlighter repair) was much better with the regular blacklight.
