Triple Thick Q...
Fudd
Kalamazoo, Michigan
i got a new zoo keeper instruction card from TOG...i need to triple thick my bezel. do i...
triple thick the bezel first, then put on the card, triple thick over that.
or
put the card on first and triple thick over everything.
Not familiar with a zoo keeper, but I would triple thick with the window for the instruction card (and the screen viewing area!) taped off. Peel the tape when dry and install the card.
I wouldn't spray triple thick in blank area it'll end up a lil cloudy after.
i'm going to tape off the clear areas first, then triple thick the bezel without the instruction card...i guess my question is, after i triple thick the bezel do i add the repro instruction card and triple thick over it? should i worry about the card flaking off again?
Be careful taping the clear areas.. I did this on a cocktail top, and it pulled up some of the ink.. Maybe score it first before removing the tape.
If the artwork isn't already bubbling on the ZK bezel, and if you don't plan to store the game somewhere with drastically fluctuating temperatures or humidity, the triple thick is probably unnecessary.
the artwork doesn't seem to bubble on taito games...both on my qix and zk its flaking off...i triple thicked both of them in attempt to save them.
and we live in michigan....its 80 one day and 50 the next.
Do you keep your games outside?
We do have some crazy weather though.
