Luddite
I have a tri-sync monitor that probably has a bad yoke. I found a television that uses the exact same tube number. Can the yoke possibly be used from the television? I have read a couple different things about not being able to use a VGA yoke with a television yoke. But this is a tri-sync monitor. Is there any difference?
The chassis is good so I would rather not have to buy a whole new monitor but I am not sure about the whole tri-sync swap with a television yoke.
What do I need to make sure the yoke is ok for swapping? only check the impedence?
