Trapshoot classic - remote issue or transmitter issue?
I posted about this a while back but thought I would revisit it. My Trapshoot Classic wall game uses an RF garage door opener as the trigger. It works most of the time but intermittently stops firing. I thought at first it was because of the complicated series of buttons on the switch (pics below). However, the light on the controller flashes each time it's pressed so I know the switch is operating right.
Any ideas on how to check to see if the problem is with the remote versus the receiver? I suppose it could be an interference problem out there of some sort but I don't know how to test for that either.
Here's the controller:
As you can see, the red button on the housing simply presses on a standard garage door opener remote button made by LiftMaster:
Which, in turn, presses on the small I-beam looking white plastic piece:
Which then presses down on the tiny electronic switch button:
