Gruber
very cool room mod!
Looks great!
Did you buy frosted plexi or did you sand?
Did you edge light it, or is it lit from behind?
I've been working on a ceiling lighting system using the RGB LED strips but I'm having to use a completely different diffusion material to avoid a spotlight effect from the LED's proximity to the plastic.
Awesome work!
Thanks for the indepth reply!
It sounds like I'm not too far off the mark in my progress then. I can get away with more sins because I will have about a 6" gap between the LED's and the diffuser, great tip about the backdrop though, I hadn't thought about that at all!
Awesome work! I love the effect. I think you've described the effect I'm looking for for a game room sign I'm making.
Would you mind telling me where you found white masonite? I've never seen or heard of it around here.
Thanks!
Tom
Hi Tom,
It goes by a bunch of mislabelled different trade names...melamine....tile board....masonite....etc...but I purchased mine from Home Depot....4' X 8' sheet was $12. It is in the plywood isle...
Alan
Hi Tom,
Alan
If it's the stuff I'm thinking of it looks like a big dry erase board, and actually I have used it as a huge dry erase board before. It should be back where the other masonite is, along with the peg board.
That is wicked. Nice job Alan. When is your gameday again?![]()
