Traded a ms pac man for a suski 8 hour
firepowerplayer
iron station, North Carolina
My neighbor bought it working at an auction, and left in in an enclosed trailer for a year. Now the right side monitor is dead and the left is having trouble with its verticl positioning. It seams that it folds over on its self in the top of the screen. I have no ideal what to do except check the fuses, which were good. Any Ideal where to start would b great. Thanks.
The monitors are going to need repair. Usually foldover is something you can cure with replacement capacitors, and generally speaking, it's best to start out by just replacing all the electrolytic capacitors at once, also known as a "cap kit".
You need to figure out what kind of monitors are in the game, if you can't figure it out, post some pictures of them, and we can identify them.
The dead monitor could be any number of things, from a fuse or a connector to a flyback or a HOT failure to something even more complicated. But again, we'd need to know what kind of monitor it is to be able to point you in the right direction.
-Ian
