Trackball with Arcade SD
GMK77
Donor 2015-2016
Delaware
Can someone walk me through connecting a compatible trackball to the Arcade SD? Am I correct in assuming it will need to be soldered into the jamma harness? Thanks for any help.
Thanks. I found that pic shortly after I posted. Any way to do it that doesn't involve soldering?
You don't HAVE to solder. You can cut the wires in the harness and use a butt splice or pigtail to crimp them together.
