Trackball Wiring Harness
hindered
Donor 2015
Kalamazoo, Michigan
Anyone know a part number / source for the smaller connector that goes from the trackball to the game PCB, like on a Golden Tee? I'm looking for the 6 pin connector that attaches to the PCB itself, not the one that attaches to the wires from the trackball (I have plenty of those already).
Thanks!
I might have this in a box of GT parts from when I stripped a damaged cab...
my bad, the numbers I gave you are for .156. You need .100, and I will have to look up those numbers. sorry
Hehe shit happens, brother.
These ones? http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_234747_-1 Or these ones? https://www.jameco.com/webapp/wcs/s...01&langId=-1&catalogId=10001&productId=878500
With these pins?
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_234923_-1
What can the ones I ordered be used for? They look like they'd work for RGB/Ground connectors to std res monitors?
With these pins?
Most trackball connections are .156 on both ends.
Yes, the numbers that you have listed will work fine for .100 headers.
Yes, most monitor video headers are .156 and the ones I told you about can be used for monitors.
Maybe most of the older trackball ones are but everything "recent" i've seen is 6 pin 3x2 housing on one end and 6 pin .100 on the game board.
